73-87 Chevy _ GMC Trucks => Electrical => Topic started by: 1987copper..v10 on January 11, 2024, 06:26:55 pm
1987 v10 dome light, horn not working. I've got hot going to dome and checks out fine, ran continuity with multimeter on ground, and get a decent reading, assuming i'm reading multimeter correctly. I thought ground(orange/white running to dome) may be corroded running through door threshold, so I cut it by fuse box, pushed on horn...and nothing, so i assume that ground is fine....Checked ground cluster behind instrument panel, detatched , inspected connections, everything looks fine, no corrosion.... checked door/dome light switch on driver side, looks perfect
Are you sure the dome lamp bulb is good? Orange is B+, white is switched ground. Reconnect the wires that you cut. Probe the orange wire using a test light clipped to ground to verify battery voltage. Then jump the white wire directly to a shiny clean bare metal ground. Does the dome lamp illuminate?
I had this same exact problem about 15 years ago on my 85. I think it was a fuse, caused by a bad ground. Check your fuses. Clean the ground on the left rear tail light. It didn't make sense that it was all connected.
Bulb is good...orange is good, fuse is good, I think the ground is ony half good, or half bad, haven't worked on it yet... thanks for the replies, I'll update once I get a chance to work on it.
