73-87 Chevy _ GMC Trucks => Electrical => Topic started by: Mr. Machanic on March 04, 2024, 10:40:45 am
When I got Bigg'in, the passenger courtesy switch was rusted and froze up solid.
Eventually, ordered a set from a catelog.
Weather finally broke enuf to tinker outside, so after removing the passenger switch, it was guickly discovered the threads were not a match.
The factory threads are 3/8-24 and the new ones are 5/16-18.
Had it not been the fact that the bodies of both are a match, I would of ordered a replacement.
So, what to do about the threads?
How about a thread adapter bushing?
....half an hour later....
A brass bushing with 3/8-24 external threads and 5/16-18 internal threads was in hand. A little thread locker to keep the bushing on the switch and the new switch was installed and functioning like intended. And since 2 came in the package, the driver's side was done as well.
Now, eventhough I made mine on a lathe, the same could be done with 3/8-24 thread-all, a .257 drill and 5/16-18 tap, on a drill press.
It might take a little longer and not be concretic, but it will serve the same function, so don't be discouraged. You can do it. And since thread-all comes in at least 12" lengths, there is plenty of material to practice on.
Fine work! :D
Definitely the wrong ones.
