73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: philo_beddoe on April 18, 2024, 04:08:42 pm
Title: Something is scrapping the driveshaft!
Post by: philo_beddoe on April 18, 2024, 04:08:42 pm
Well, I know what is hitting it, had lots of bags of soil, mulch, that sort of thing in the bed, on way home from wmart, when hitting a drop in the road, or bump, I could hear the scrape. Why is this hitting, can I cut a space in this stupid rivited on box? And why is it rivited, and not simple bolts?
 (https://uploads.tapatalk-cdn.com/20240418/fb65f32a621f3bc37ac2a3bdb2b5d32d.jpg)
Title: Re: Something is scrapping the driveshaft!
Post by: Swampyankee74 on April 18, 2024, 06:36:27 pm
Looks like a bracket for a bearing on a two piece driveshaft.  If so grind the rivets off and pull the bracket
Post by: Scott91370 on April 19, 2024, 11:05:20 am
I agree, it does look like it would be a carrier bearing mount.  If you're never going back to a 2 piece drive shaft, just cut the entire mount out.
Post by: philo_beddoe on April 23, 2024, 08:44:48 pm
Yup, so far that’s the plan. Thanks
Post by: philo_beddoe on April 28, 2024, 10:24:08 pm
Well I unriveted that useless box, gone! Cleaned the area and painted. Looks like it was never there. Will add pic when I get a chance.
Post by: Shifty on April 29, 2024, 09:29:54 am
Aww man!  Why did you remove your roadkill-scraper-mount?  ;D
Post by: philo_beddoe on May 21, 2024, 06:26:12 pm
Post by: philo_beddoe on May 21, 2024, 06:42:13 pm
(https://uploads.tapatalk-cdn.com/20240521/b00c172257bb19b811c878385528f232.jpg)
Carrier bearing support bracket gonzo….
Post by: Shifty on May 23, 2024, 09:48:08 am
Look at you, lowering that drag coeffecient!  OK, still a brick.... ;D
Post by: philo_beddoe on May 23, 2024, 10:33:53 pm
