73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Dr_Snooz on January 28, 2025, 09:10:26 am
My '89 350 has these amazing cast aluminum accessory brackets.
(https://1drv.ms/i/c/5667f57ff74aa46c/IQRNlu6FCN5dRaIecDgvC4vKAXic5fkRIMzUrpEmqsor9X4?width=1024)
The brackets use these spacers to align the pulleys.
(https://1drv.ms/i/c/5667f57ff74aa46c/IQTBc8WAKhuwT7XMJA_NAE_tAdq3sLr7mWZrFX8bRE3qiMQ?width=1024)
One of my spacers has gone missing. I'm trying to find a new one, but don't know what to call it, or the GM part number. Nor am I having much luck searching the online parts catalogs. Nobody has any drawings or anything.
Can someone help me out here?
And please ignore my mismatched valve covers lol.
Hmm, I am not sure where you would acquire that. I would possibly start with the local Dealership to see if they can identify if it was available.
What about those little "hat" type wheel retainers that you see on tricycles, wagons, etc...my local ACE has them....just drill out the end.
It's a flanged bushing.
I can work with that. Thank you!
You might try looking for bushings with McMaster-Carr
Oh, and get some matching valve covers... ;D
Technically it's a split flanged bushing. If you google it you will see them.
Ack! You caught me! I'm so embarrassed. LOL
Look, they match now. Good grief.
(https://1drv.ms/i/c/5667f57ff74aa46c/IQQJY7pH5SWFR5am5BHYA69BAejxHzIfSphNiX-rtniLmqU?width=1024)
They're both trash, BTW. All pitted and nasty with rust. I would replace them, but they're expensive.
I can't find these bushings anywhere. I'll just keep rocking the flat washers I substituted in there temporarily. Hope the tab doesn't break off.
Check your dimensions
https://us.misumi-ec.com/vona2/detail/221000090936/?HissuCode=LFF-3015
https://www.allworldmachinery.com/itemdetail/LFF-1415
https://www.wychbearings.co.uk/f0805-5l10_bush.html
https://www.tme.com/in/en/details/skfpcmf081009.5/plain-bearings/skf/pcmf-081009-5-skf/
My dimensions are 0.515" D x 0.549" OD x 0.425" ID x 0.106" shoulder thickness. I should just design one with OnShape and have them made.
