73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Rough75C20 on May 19, 2025, 06:03:45 am
Hello,
I replaced my thermostat this weekend due to it sticking and overheating. On the initial drive, temps were staying within a good range 180-210 degrees F. On the second drive, temp never increased above 150 degrees F. I believe the new thermostat got stuck open. I do have the housing with the temp sensor port, so I was going to open that and check to see if the thermostat is sticking up, but what could cause this? Do I need to flush the coolant out of the system and refill with all new? Not sure what would cause this as it was working normally on the first drive. No coolant is leaking from anywhere I can see.
Also has anyone used the aluminum / silicone gaskets for the thermostat housing from amazon? Do they work better than the paper gaskets? any need for RTV with those.
Thank you
No need to RTV the gasket. If you used a failsafe thermostat it probably failed.
It is a fail-safe thermostat. do these fail often when they shouldn't? Should I replace with a different brand? does the no RTV go for all thermostat gaskets (aluminum and paper)?
Either use RTV or a gasket, there is no reason to use a gasket and RTV. Failsafe Thermostats are garbage.
Thank you. Any recommended ones that aren’t trash right out of the box?
I guess what I am wondering is would it be better to get a balanced thermostat vs a regular spring piston type? Are they more reliable? Is it worth the extra cost?
The Robert Shaw unit has always worked well for me.
Just a follow up.
Went with a regular duralast gold thermostat and the aluminum / silicone gasket from Amazon. Working well with no leaks. Thanks guys. Was skeptical of the gasket at first but dry all around.
