		73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: greatwhite on December 12, 2003, 08:54:00 pm
				ok well here's my problem i have headman longtube headers and the collecters are like an 1/8 of an inch away from the bolt of shackle for my front leaf springs.so when i start the truck they rattle against the bolt and which not only sounds obnoxious but will eventually wear a whole through the collecter.  Im pretty sure there isnt anything i can do but i thought id give it a shot.  Oh and i tried to give the headers a little "tweak" thats how i got the 1/8 inch
				Maybe get longer shackles? Or longer leaf springs and relocate the hangers, or different headers....
				thanks, i was thinking of longer springs.  I want to probably do a 6'' lift so i need new springs anyway i wasnt sure if i could find longer springs and if i could if i could use them.  I know there are alot of things you cant really mess with due to messing up the geometry of the front end.
				I dont think getting longer or shorter springs would actually change the geometry since the axle location will not change. I believe the two different lengths are 52" and 56". I want to put an 8" lift on mine but money is tight this time of year, and my tranny decided to start giving out on me last week.
  Glad I have already done most of my xmas shopping. Now to find a decent tranny shop for a rebuild.
				Do you have access to porta power with a clam shell attachment? If so I would use that to give your self some real clearance. Do it while the headers are hot they will bend allot easier and wont stress the metal as much.
				When you bought the headers, were they for a 2wd vehicle, or were they designed for a 4wd vehicle? I would verify that. If they were designed for a 4wd vehicle, I would also call headman and give them ten million question speech about your problem. Good Luck
				i had the same problem with heddman and i resolved to cutting the extra length off the bolt and it allowed enough clearance so they woudn't touch.  if it still does i would check your motor mounts they may be worn and allowing too much movement.
