		73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: zooracer on September 29, 2004, 12:46:00 pm
				I have an 81 with the full time hubs.
I can easily shift down to 4 high, but it will not go down from there to 4 lo.
Any suggestions?
matt
				did you check your linkage at the transfer case?
I used to have a 79 blazer with full time and the linkage got loose once and gave me similar problems
				Ok, will check the linkage out.  Maybe just try to adjust it...
Thx
				make sure that when you shift to 4 lo that the tranny is in neutral
