73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: Silver78ado on January 15, 2005, 01:40:00 pm
Title: Need some opinions.
Post by: Silver78ado on January 15, 2005, 01:40:00 pm
I have a 78 K10..and as we all know the rear end decided to defect on me..lol..well the truck has a 3.07 gear..wich i asume is a 3 series carrier..the truck also has a 4" lift and 34"tires what gear would you all think would be the best i would like to go with a 4.10 in a 3 series the motor will get a mild overhaul this spring when it warms up i'm not looking to build a 4wheel monster just a decent balanced power pack.and how do you all feel about the 342 or 373..what ever i do to the rear i will do to the front this spring..just looking for options..any sugestions would be great..thanks yall
Title: Re: Need some opinions.
Post by: TRUCK6DRIVER on January 15, 2005, 10:15:00 pm
Do the math on tire size from stock. If you had 31" tires factory and now run 34" , if you do a diameter correction you should come close to the right ratio for engine RPM's and speedo correctness.
