73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: Olaf73 on January 18, 2005, 01:02:00 am
Title: Gearing Problem?
Post by: Olaf73 on January 18, 2005, 01:02:00 am
My Girlfreind just scored a 73 Chevy pickup(Crate 350, SM465, NP205, 4" Lift, 35's).  When in 4H or 4L, the rear end chirps alot, like the gears in the axles are different.  I dont think its a locker, because it does it at idle, in a straight line.  After, its a pain to get it out of gear.  The front has a tag that says 41.11-3.73, what ratio is this that?
Title: Re: Gearing Problem?
Post by: roundedline on January 18, 2005, 10:26:00 am
What is chirping?  The tires?  We need more info.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: Olaf73 on January 18, 2005, 05:05:00 pm
Ya, the rears chirp like if you were cornering with a locker.  We even took it out to the dirt, same thing.  I think im gonna have to pull the covers and check the gears.
Post by: BigBowTie75 on February 23, 2005, 04:51:00 pm
check the gears it souns liek they have different gear ratios cuz my first chevy did that some one had a 3:55 i nthe rear and a 3:73 front
Post by: 1984 K20 on February 23, 2005, 09:47:00 pm
As for your question about the tag on the front. If you were still wondering, it means 41 teeth on the ring gear divided by the 11 teeth on the pinion which is approximately a 3.73 gear ratio.
Edited by: 1984 K20 at: 2/23/05 9:55 pm
Post by: Blazin on February 25, 2005, 09:24:00 am
When i first got my Balzer it did that and ended up tossing a drive shaft into the floor the first trip out. It had 3:73 in front and 2:73 in the rear.
