73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: lomarrius on June 08, 2005, 01:59:00 pm
Title: 4x4 help - transfer case works, hubs don't
Post by: lomarrius on June 08, 2005, 01:59:00 pm
Hi;
As you can tell by my other posts, I am currently certifying a 1983 Chev Blazer 4x4 305ci
The 4x4 doesn't work. It has limited slip on front and rear.
The guy I bought the truck from (for $400) said that 4x4 worked, but when I jacked it up to investigate, I found that:
The transfer case engages no problem. However, the front wheels don't turn in 4x4.
I would imagine that this is a problem within the hubs.
Wondering if any of you can specifically mention which part may be broken that would stop the wheels from powering.
I have the service manual, but I want to research these problems before I start taking the hubs apart.
Thanks
Title: Re: 4x4 help - transfer case works, hubs don't
Post by: 79 4x4 on June 12, 2005, 05:43:00 pm
I had the same problem, one of my hubs had broke.
Post by: roundedline on June 13, 2005, 05:46:00 pm
Neither wheel turns?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Title: Hubs
Post by: CruzinHigh on June 18, 2005, 09:41:00 pm
That's exactly the same story for me when I bought my 86 C-10.  The front "auto engage" hubs were not allowing the 4x4 to engage.
I swapped them out for some WARN manual locking hubs.  Its a pretty easy change out, you may wish to buy the 4x4 hub adaptor for about 10 bucks.
Title: Re: Hubs
Post by: skynyrdfan86 on June 24, 2005, 05:50:00 pm
to me it sounds like the hubs are not fully locking where it will lock the front axle i could be wrong but i would try pulling the locking hubs to see if they are broke and you might need to replace them..
