73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: DainBramaged on March 13, 2006, 10:07:00 pm
Title: Crazy Fuel Gauge
Post by: DainBramaged on March 13, 2006, 10:07:00 pm
Hi all, I am working on wiring up my truck and have a question about my fuel gauge.  I have dual gastanks and the left hand gas tank gives a correct reading, however when I switch it over to the right hand gas tank it gives a reading way past the full mark.  I replaced the switch for choosing the tank also, which seems to be functioning fine.  All the other gauges seem to be working correctly.  Any ideas?
Title: Re: Crazy Fuel Gauge
Post by: 123 pugsy on March 14, 2006, 05:49:00 am
I have the same problem ,but just a single tank the fuel gauge is as yours.I think I will check the ground as I just painted the frame.Anyone else???
Post by: DainBramaged on March 14, 2006, 09:58:00 am
I am starting to think maybe I have a bad ground too?  I am not exactly sure how my setup works... I think a pink wire from each sending unit runs to the fuel tank switcher, and each sending unit has a ground near the gas tank?  A reply from anyone who knows exactly how this is supposed to be wired would be greatly appreciated.
Post by: shaved80 on March 14, 2006, 10:19:00 am
my dads truck does that. i just hold the switch on whatever tank is doing it for a while then it eventually drops down to the right reading
Post by: roundedline on March 14, 2006, 02:58:00 pm
The wire to the guage should be brown or pink.  There should also be a ground wire running from the sending unit to the top of the frame.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: 123 pugsy on March 19, 2006, 09:29:00 pm
Checked my ground wire and that was fine.Poked the test light though the tan wire and it lit up dimly as I have about a 1/4 tank,if that, so that seems OK,but it still shows way over full .        Anybody out there have this problem before????
Edited by: 123 pugsy at: 3/19/06 9:29 pm
Post by: DnStClr on March 21, 2006, 09:50:00 pm
If the ground wire is ok, the sending unit may have come apart. Mine did, and my gauge did the past full thing. when I dropped the tank, replaced the sending unit and soldered a new ground at the tank, it worked ok.
Post by: cheyenne77 on March 23, 2006, 08:45:00 pm
Been there, It's time to drop the tank and take a look. It's a good chance to clean out rust and setiment. I ended up replacing the sending unit. My brother truck did the same thing, We dropped the tank and found out the float somehow ended up under the tank filter. Of course it was an off road vehicle.
Post by: markzepp820 on March 28, 2006, 07:31:00 pm
Mine did the same thing also. I checked the ground and there was a bad connection to the frame. sanded to the bare metal and solved the problem.
Post by: 123 pugsy on April 02, 2006, 05:28:00 pm
Got the tank dropped today and the sending unit is toast.Order a new one tommorow and hopefully the fuel guage works after that.
Post by: 123 pugsy on April 03, 2006, 05:21:00 pm
Sending unit was the problem.Fixed that and now I've discovered another problem! I'm almost out of gas.
Post by: bfofish on April 03, 2006, 07:18:00 pm
i hate it when that happens!
Edited by: bfofish at: 4/3/06 6:19 pm
