73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: drivit on April 15, 2006, 08:27:00 am
my backup lights stoped working, i figure its the switch but i don't know where to look for it. its an automatic.
You'll find it above your steering column under your dash. It is a white oval type switch with a few wire going to it. It screws (2) right to the top of the column about a foot from the firewall. these things are cheap and easy to replace. Make sure you follow the instructions--you have to place a drill bit in the slots during installation to keep it from moving.
You'll know it is bad if your engine will turn over while in D or L's or R. It isn't supposed to.
try your fuses first b4 getting a new switch!
SgtDel Edited by: SgtDel at: 4/15/06 8:17 am
thankyou, that was a big help.
Hey, mine just started being able to start in any position. My lights still work though.
1976 scottsdale, you need a new "safety" switch. see the reply above.
