73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: 75 C20 on April 24, 2006, 09:16:00 pm
Title: aprox. HP
Post by: 75 C20 on April 24, 2006, 09:16:00 pm
i have a 1975 C20 with a 350, granny manual trans. i have headers, new edelebrock 600 cfm carb., alum. gm preformence intake, straight pipes and glasspacks. Any Body got an Idea of aprxamately how many horsepower i got??
Title: > aprox. HP
Post by: Lt.Del on April 24, 2006, 08:38:00 pm
You didn't mention if your engine is stock for the vehicle...makes a difference.
If it is stock, It probably had about 180 horses.
SgtDel
Title: Re: > aprox. HP
Post by: 1974Super10 on April 24, 2006, 10:38:00 pm
Around 230-250 horse, depending on the year of your motor... It would depend if the Cylinder Heads were 64cc or 72cc
Post by: 75 C20 on April 25, 2006, 07:38:00 am
yeah it came stock with the truck
Post by: Lt.Del on April 25, 2006, 01:25:00 pm
I am sure there wasn't over 200 hp in those years.  About 180 hp.
SgtDel
Title: Re: Re: > aprox. HP
Post by: Z28 c10 on April 25, 2006, 07:34:00 pm
Get the engine code off the pad behind your alternater on the block and cross referance the last three letters,suffix code, on this link--
www.nastyz28.com/spmenu.html
For instance, mine shows CNB as suffix code, so I click
CMK- CUD, follow the codes down to find CNB and, viola, I've got a 1970 Z28 350 with advertised 360 factory hp. Now you have to take into account that that's flywheel hp. The drivetrain takes up a bit of power, but, it gives you a really good idea at what your dealing with.
 JayTater
 Z28 C10
Title: hp
Post by: 75 C20 on April 26, 2006, 08:07:00 am
i'll do that, thanks
Title: Re: hp
Post by: roundedline on April 26, 2006, 05:37:00 pm
Keep in mind the Suffix code only is valid IF the internals that were in it when it left the factory are still there.  Just becuase it has X suffix on it doesn't mean you have a 360hp block, it just means you have a small block chevy.  The code along with the VIN ties it to a specific car/engine.
The 1975 C20's had 160 hp stock.  You may have gained 15hp.  But the engine is 31 years old and it probably doesn't have 175hp anymore...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 4/26/06 4:38 pm
Title: Re: hp
Post by: DnStClr on April 26, 2006, 08:47:00 pm
Roundedline, the 160 hp- is that off the engine or the rear wheels?
Title: Re: hp
Post by: roundedline on April 26, 2006, 10:50:00 pm
At the crankshaft.
Project Su
Jimmy 2WD Project
