73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Leadfoot on May 02, 2006, 02:01:00 pm
Title: gas gauge wiring help
Post by: Leadfoot on May 02, 2006, 02:01:00 pm
I need some wiring help.. my `82 truck came with the dual tanks..I have done away with both tanks and the switching valve and installed a suburban tank in the back between the frame rails.. the new tank only has the ground and the pink wire from the sending unit,anybody got an idea where I need to hook this in to the original wiring to get a functional gas gauge??
Thanks,
Edited by: Leadfoot at: 5/2/06 1:02 pm
Title: Re: gas gauge wiring help
Post by: roundedline on May 02, 2006, 02:40:00 pm
The switching valve should have had a sending wire to it and each tank should have had a ground running to the frame rail.  If you know where the wire is for the sending unit, then you can just hook it back up.  As for the ground, just ground it to the frame.  I was thinking the sending wire was brown...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: 123 pugsy on May 03, 2006, 09:10:00 am
Don't know about dual tank trucks,but mine comes down thru with the wire for the starter motor.
Title: WIRING
Post by: Leadfoot on May 03, 2006, 10:52:00 am
Thanks for the help..I'll see what I can find..
