73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: 1funnyfarm on June 05, 2006, 10:46:00 pm
Title: 78 silverado
Post by: 1funnyfarm on June 05, 2006, 10:46:00 pm
Hi just wondering if there is anyone out there that could tell me what the towing capacity is for a 78 silverado, two wheel drive?
thanks!
Title: > 78 silverado
Post by: Lt.Del on June 06, 2006, 07:46:00 pm
The answer greatly depends on the options.  Rear end ratio, engine, etc...
SgtDel
Title: Re: 78 silverado
Post by: Blazin on June 06, 2006, 08:32:00 pm
1/2, 3/4, or 1 ton?
Post by: DnStClr on June 06, 2006, 11:33:00 pm
And also if you're talking about towing as a pull-behind or as a fifth wheel. A truck is rated for much higher towing ratings when used for fifth wheel towing.
Post by: Ziptar on June 10, 2006, 07:12:00 am
I have a 79 Silverado 1/2 Ton with an Olds 5.7L Diesel. According to the owners manual it is limited to 2000 lbs towing capacity, so as you can see towing capacity varies widely based on the engine, trans, and suspension.
1979 Silverado C10 w/ Olds 5.7 Diesel
85 C10 Custom Deluxe
