73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: SUX2BU99 on June 18, 2006, 01:45:00 pm
Title: Leaking Edelbrock fuel filter. Dried out?
Post by: SUX2BU99 on June 18, 2006, 01:45:00 pm
85 Chevy SWB FS 2wd mild 350. I haven't driven it in a month to 5 weeks or so. Not started the motor either. I fired it up yesterday and found that my 1-1.5 year old aluminum Edelbrock fuel filter with replaceable cartridge was dripping quite a bit of gas, right onto my valve cover over my headers 8o   I took it off, took it apart, cleaned it out and put it back on the drip was still there. Did the rubber O-ring perhaps dry out in that month of non-use? Freaked me out since that is obviously a potential fire waiting to happen. It was leaking right where the 2 halves screw together and are sealed with an O-ring. It didn't LOOK warped or anything but who knows.
Thanks!
Title: Re: Leaking Edelbrock fuel filter. Dried out?
Post by: VileZambonie on June 19, 2006, 04:06:00 pm
I hate those fuel filters. Just get a clear 3/8" fuel filter.
Post by: 75 C20 on June 20, 2006, 05:31:00 pm
i don't think there bad- just try a new rubber o-ring
Edited by: 75 C20 at: 6/20/06 4:31 pm
Post by: SUX2BU99 on June 20, 2006, 10:56:00 pm
Any idea where I could find just the O ring? Would it be anything special? I ended up buying just a regular canister-type Fram filter for a whopping $4 and it did the trick. But I don't want to waste the $20 Edelbrock just because of a bad O ring.
Post by: 75 C20 on June 23, 2006, 02:51:00 pm
just take the old o-ring out and go to ne napa or advnaced autos etc... and they should be able to get a o-ring- i dont think they are ne thing special...just a old standard oring
Post by: DnStClr on June 23, 2006, 04:53:00 pm
Some o-rings will not work with fuel and solvents. If the're made of the wrong material they will swell up. And leak.
Don St.Clair
Culleoka Tn
