73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: gpday06 on July 02, 2006, 06:54:00 pm
Title: gauges
Post by: gpday06 on July 02, 2006, 06:54:00 pm
where can i get white face gauges that i wont have to do any work to change anything just put them right in i need the speedo, fuel, volt, oil press, clock, and temp all electric except for the speedo, ive tried autometer with no luck any help will be greatly appreciated thanks! '79 C10
Title: Re: gauges
Post by: shaved80 on July 02, 2006, 08:50:00 pm
if you don't want to do any work to make them fit, you're only option is white faced stickers
search.ebay.com/search/se...category0=
Title: Re: gauges
Post by: gpday06 on July 02, 2006, 11:38:00 pm
nevermind i found the work thats been done online, ill do that
Title: Re: gauges
Post by: gpday06 on July 02, 2006, 11:42:00 pm
another question, i have the 5" fuel gauge but want to make it a small gauge like the volts, oil press, and temp, and would like the 5" tach, how would i go about changing that? do i have to buy another printed circuit and if so how do i run the wiring for the tach to the wiring harness for the printed circuit?
Title: Re: gauges
Post by: yellow76 on July 04, 2006, 12:16:00 am
covansclassic.com/parts/items.php?CA=21&UID=2006070401121668.113.47.73
These have got to be the sweetest set up I have seen yet.
I am saving my pennies- Just 5000 to go.
76 stepside 2wd
GMPP 350/350
basicly a big money pit, but a lot of fun.
Title: Re: gauges
Post by: roundedline on July 05, 2006, 11:38:00 am
You need a tach cluster to do the least amount of work if you want a tach.  You will still have to repin the plug that goes into the cluster.  There is no unplug/plug in cluster that has different instruments/lights unless you use one identical to what you have from '78 -up.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
