Are you looking to buy or looking for information on where to buy?
If you are looking to buy, this needs to go to the Parts Post. If you are looking on where, www.usautoparts.com/ has kits, or did at one time. They were actually frontends from salvage pickups, what they are now, I don't know... Chris Lucas
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
You need (from Neil's write-up) posted above...
Parts List:
‘89-’91 Radiator support GM part #15641713 *
‘89-’91 Grille (center portion) GM part #15628796 *
‘89-’91 Right headlight/turn signal bezel GM part #15628670 *
‘89-’91 Left headlight/turn signal bezel GM part #15628669 *
4 - ‘89-’91 Headlights, headlight buckets and trim rings GM part #16503172 (RH low beam), 16503171 (RH high beam), 16503162 (LH low beam), 16503161 (LH high beam)
‘89-’91 Right Turn signal lens GM part #5975228 *
‘89-’91 Left Turn signal lens GM part #5975227 *
4 - ‘89-’91 Headlight “pigtails” *
8 - ‘89-’91 Headlight adjusters *
4 - ‘89-’91 Headlight springs *
You can get a grille from any of the above trucks, BUT you HAVE to have the 89-91 core support from the Burb/Blazer also or it won't work. Chris Lucas
Project Su
Jimmy 2WD Project
