Does anyone know the exact dimensions for the bed bolts? 8' Fleetside.
As in diameter and length? This is for the 8 holding it down right?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Yeah I know they are 1/2" carriage bolts and one is long...
Let me see if I have one here...
Project Su
Jimmy 2WD Project
bump
Bolts are 4-1/4". Long ones should be 6-3/4" longer (frame thickness) giving you 11".
Hope this helps.
Pugsy
Thanks Pugsy! I forget, how many long ones are there? Just two? I ripped the bed off this thing 3 years ago and torched the bolts so I can't remember!
Should be 2 and 6 I believe.I've got 6 shorties on mine due to the fact I have a newer box on an older frame.
Should be one long one. Typically it is on the drivers side away from the fuel lines. I have seen them with long ones on both sides though.
Project Su
Jimmy 2WD Project
