wut is the best way to go about undercoating/painting my frame. i dont know if i want to undercoat it or paint it yet. im just doin the engine compartment now and then maybe next year ill do the bed and cab. i dont have a sand blaster to blast it either...
Are you going to remove everything or not?
I would suggest POR15. It can be painted over rusty surfaces. You just have to remove any scale. Chris Lucas
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
I plan on removing all scale but not cleaning the rest of the frame down to bare metal. i think if i can find something glossy id like it better but i dont know yet....
Por15 will be glossy if you apply it thick enough. Good stuff.
I sandblasted my frame and then used the Eastwood Rust Encapsulator and Frame Black. I have since covered it all with another coat of gloss black. It has held up well. If I had it to do again I think I may have used the POR15, but when I did mine the POR was just starting to be used.
