73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: mort2202 on January 31, 2007, 06:20:00 am
Title: c10 gauge cluster swap
Post by: mort2202 on January 31, 2007, 06:20:00 am
hi,i'd like to swap out my non tach 1984 gauge cluster for a 1977 gauge cluster with tach. does anyone know where to obtain wiring schematics for these two chev 1/2 tons.?
Title: Re: c10 gauge cluster swap
Post by: Tire Burner on January 31, 2007, 06:22:00 am
brochures.slosh.com/index.shtml?1986
Try this site. I used it when i put in my Autometer Gauges. You'll have to click "Wiring" Under the Heading "Technical Info"
Post by: roundedline on January 31, 2007, 08:54:00 am
Any Haynes manual from AutoZone will have the schematics, or the Helms manuals for these trucks will have them.
Going from the 84 to the 77 you are going to be doing alot of wiring changes.  The 77 uses mechanical oil pressure senders.  A plug n play model would have been any 78-up.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: joesgarage71 on February 01, 2007, 09:55:00 am
Autozone also has wiring info click on repair info.
Steve
