73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: iroc88 on March 04, 2007, 07:19:00 pm
Title: w/s wiper help
Post by: iroc88 on March 04, 2007, 07:19:00 pm
i have a80 k10 wipers are slow.ck all grounds,replaced motor still slow. is there any other wiper motors that will work with minor mods. thanks john
Title: Voltage drop
Post by: VileZambonie on March 04, 2007, 08:25:00 pm
Well then it's one of two things
1)Mechanical resistance
2)electrical resistance
If the winshield is wet do they work normal?
Do you have a volt meter? You can do a simple voltage drop test before the motor, at the motor and or after the motor.
Essentially you should drop all source voltage at the motor. There should be no voltage drops before or after which would indicate resistance and give you that slow motor.
Title: Re: w/s wiper help
Post by: Blazin on March 05, 2007, 06:44:00 am
Try lubing the wiper transmision assembly.
