hey folks, I just bought a '77 chevy 4x4 pickup from a friend of mine down in South GA, it's a great truck! but after some investigating found out the VIN and the truck as it is now don't match! Here's how the truck as it is now:
1977 Chevy 4x4 pickup
LWB
stock SB 350 engine w/4 bbl quadrabog
stock exhaust man.
TH350 tranny
ain't washed the grease off the xfer case to get any #'s on it.
locking hubs
3" suspension lift (cheap block setup for now)
3" body lift (looks a lot better than I thought it would)
Anyways here is my breakdown of the VIN:
C=Cheverolet
C=conventional cab (?? what? K= 4 wheel drive and it's a 4 wheel drive!)
S= 454-4 (?? what!? truck has a 350 in it! L=350-4)
4= heavy half (whatever that implies)
4=pickup
7=1977
A=Lakewood Assembly plant
155,844=build sequence (truck was the 55,844th unit produced)
I took some pics of a sticker on the inside of the lid to the glovebox, here they are:
Can anybody tell me how this C10 morphed into a K10? Sorry if I'm not clear on all this. I'm just curious how my truck went from the truck described by the VIN to the one it is now. Funny, I was thinking about dropping a 454 in it before I researched the VIN. Tell me what ye think!
thanks!
Jimbo
Good question! Someone must have converted it or replaced the cab with a 2wd unit? Some strange things have happened with engine codes i think. My 1980 3/4 ton has an engine code of 'x', some decodes show it as a 400 while others don't show it at all. The motor is a 350.
SERIES PAYLOAD #
C10 960 - 2680
BIG-10 1980 - 2355 (heavy half)
C20 2075 - 3930
C30 2125 - 5720
K10 1790 - 2495
K20 2120 - 4250
K30 3795 - 5345
This is what i could find.
U could wright down the vin ill carfax it for ya tells ya if its was wrecked and what all was done with it..I bought a car fax and its going to waste :/ update never mind...car fax is for 81 and up sorry..
Edited by: Redneckchevy at: 3/7/07 3:32 pm
VIN= CCS447A155844
btw I put some thumbnail links to pics of the truck in a post to the "Get to Know" thread. Right now it's the last post in the thread.
thanks fer the replies!
Jimbo
Are you getting the VIN from the glovebox or the dash? The glovebox can easily be swapped out?
If they in fact don't match, the cab probably was swapped out. Chris Lucas
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
