73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: magnum59 on April 22, 2007, 02:50:57 pm
Title: just a question about motors
Post by: magnum59 on April 22, 2007, 02:50:57 pm
We will be removing a 4.3 from a 1985 chevy c10 custom pickup and would  really like to up grade to a 305- my question is -is this possible with out changing everything in the drivetrain?The 4.3 is tost any way and we are looking at a crate  305 for about the same price as the 4.3.
 thanks
magnum
Title: Re: just a question about motors
Post by: VileZambonie on April 22, 2007, 09:11:52 pm
You'll have to change a few things...but nothing drivetrain related. I have a 305 for sale if you are anywhere local....
Post by: Blazin on April 22, 2007, 09:14:36 pm
Bigger radiator, clutch if its a standard, exhaust manifolds, etc.
Post by: red4wd on April 22, 2007, 09:44:38 pm
Distributor, intake, exhaust manifolds are the main things if you are doing a crate motor.  I am sure you would have to move the mounts on the frame as well.  You might have to have a fan shroud to go with the larger radiator that blazin mentioned.
Post by: 123pugsy on April 23, 2007, 11:41:41 am
If you don't have A/C ,the small rad may be sufficient. Had a small rad with a 305 and it kept cool OK.That was in an 88.
