73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 76_Scottsdale on June 06, 2007, 12:06:16 pm
Title: 700R4/NP205 SWAP
Post by: 76_Scottsdale on June 06, 2007, 12:06:16 pm
I'm thinking of swapping in a 700R4 into my '76 K20. I've heard that both a shorter output shaft and an adapter plate can be used, and since I will be rebuilding the tranny anyways, I am going to use the shorter output shaft. The only other problem is that my NP205 is currently mated to a SM465. I need to know exactly what power sleeve I must change in my NP205 to make it work and if it is very easy. If it's not, then I will just trade my NP205 for one that was mated to a TH350. I know that I will have to move the crossmember, lenthen/shorten driveshafts, and run cooling lines, but are there any other large obstacles to this swap?
Thanks Again.
Title: Re: 700R4/NP205 SWAP
Post by: VileZambonie on June 06, 2007, 08:46:07 pm
why not just put in a 700R4 -NP208?
Post by: 76_Scottsdale on June 06, 2007, 09:21:23 pm
Not a big fan of the chain drive and wimpy aluminum case.
Post by: aort07 on June 12, 2007, 04:33:36 pm
www.advanceadapters.com Will have the shaft you need. I did the exact same swap in my truck. The  shaft will have a female 10 spline on it ready to mate to your 205.
