73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: bfofish on June 20, 2007, 07:09:13 pm
Wouldn't ya know it ! I recently bought a frame for my blazer and while stripping it down today,I found this
Anyone have a "simple" fix for this ??
mine was cracked but not broken out....what I did was weld up the crack and then welded a washer on it to sturdy it up
Yeah, the one red4wd just listed is what I did on mine. I would get one of the shock stud kits and use that washer since you know it is the correct size.
i had to do this same repair last week i bent up a 3/16 patch plate that covered about a half in bigger than the broken area , welded it in and drilled a hole for a new shock stod
