73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: the_legend_1981 on July 10, 2007, 04:44:54 pm
how do i fix rust that runs along my winshield at the bottom? Its just a small spot
My thought is depending on the size either weld it up, or make a small metal patch to fill the hole (after removing the rust)
i have the same exact problem. i have talked to a few old timers and they said that they would fill it with fiberglass. A very thick fiberglass. I'm actually still trying to find out different ideas as well. How bad is yours? mine goes all the way back to the windsheild at one point
I wouldn't do that, it only masks the problem for a little while as the rust you didn't remove keeps growing.
Pop out the glass and blast it.
I had this problem with my 1st cab.The entire underside of the channel was so rotted it wasnt funny, i had to cut it all out and weld in new metal.When i was done i used the stuff made by USC called ALL METAL. Its stronger then fiberglass and wont shrink swell or crack.It held up for 12 years until i cut up the cab and the section was in good condition still and didnt blister up or anything.I notice when the windshield is replaced they sometimes seal up the drain holes in the corners and thats why the channel rots out the water sits there and eats away the metal.
thanks
pat
mines not horrible it's mostly right behind the top of the passengers fender. it's not rotted all the way through tho
If its just surface rust i say grind it down and if there are pits use a small hand held sandblaster to clean the rest and you should be ok.
thanks
pat
Sand blast it then you will have a few holes to weld up. grind the welds, re sandblast it, finish it off with some fiberglass body filler, prime it with self etching primer, and high build urethane primer. Sand, and paint it.
Yeah, mines rotted all the way through. There is a huge gaping hole there. It goes back to the windshield but i dont want to take the windsheild out
You will never be able to fix it with the glass in.
is the best way to make a replacement panel?
