73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: gold84gmc on July 29, 2007, 07:59:13 pm
does anyone know if the 73-87 trucks have a build sheet under the seat? or if its somewheres else or if it even has one?
The RPO sheet should be in the glove box. You can find a site that lists each code. Someone reading this can probably link to a website.
This is the one from my 91 GMC suburban (http://www.delbridge.net/suburban)
(http://www.delbridge.net/91zg.jpg)
It is either under the hood on the inner fender or most likely in the glove box.
www.73-87.com has the RPO codes.
well i have a very short undetailed one on the inner fender, and i have another one in my glove box that dosnt say much...thats weird, cuz in my caprice i found a build sheet about the size of regular printer paper under my rear seat that listed an rpo about everything single thing
i found this on another 73-87 website-
you can try to call GM at the number listed in the link below. i haven't tried it yet, but supposedly you give them your vin number, and they send you a pretty detailed packet about the stuff that should have come on your truck from the factory along with some other info (called a "restoration packet"). it's free, but it will probably take a few weeks. check it out.
http://www.73-87.com/7387info/7387info_packets.htm
The INFO pack lists what could come on the truck, not what actually came on it. I have a couple of them.
