		73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: 76_Scottsdale on August 01, 2007, 10:19:10 pm
				I was wonderin where some of you guys get the thick cast aluminum differential covers with cooling fins/ribs on them at. This is for a Corp 14 Bolt 10.5" rear and a Dana 44 front.
 Thanks in advance.
				http://www.bluetorchfab.com (http://www.bluetorchfab.com)
 Check them out !
				Is this cover for the Corp 14 bolt 10.5" Full floating axle? It's not quite clear.
 http://bluetorchfab.com/store/product_info.php?cPath=19_20&products_id=142
				Im not sure, Give them a call. Dan is a super nice guy.
				Thanks but I was looking more for the shiny chrome looking ones that have the ribs/fins coming off them that I see alot of folks on here with. Anywhere else you could think of?
 Thanks again
				I'm interestied in that too, since my cover seems to be leaking some. I have a stock (I believe) rear end in my truck (originally an 81 GMC shorty 2wd 6cyl. 1/2 ton). What diff does it have?
 either a 10bolt or 12bolt, could be either in 81/82.
				Okay and that bolt reference is just the # of bolts in the cover and not the # of bolts on the ring gear right?
				Well it just so happens that it is the same on the cover, but it actually is referenced to the ring gear.
				http://www.cleargearz.com/
				http://www.maghytec.com/
 http://purplecranium.com/
 http://www.partshp.com/differential_covers.htm
 http://www.yourcovers.com/newdifferential.htm
