73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: okuma on August 11, 2007, 06:27:43 pm
I HAVE A QUESTION ON THE REAR BUMPER BRACKETS , DO SUBURBAN REAR BRACKETS FIT A TRUCK? I NEED TO MOUNT THE SMOOTH FRONT REAR BUMBER ON MY CHEVY. I NEVER IMAGINED MY BRACKETS WERE DIFFERENT FOR THIS BUMPER... >:(
From a Suburban/Blazer: Outers are the same, inners are not the same.
BTW: Step bumpers for a pickup are nothing like the factory bumper, so none of the brackets will work.
THANKS , DOES ANYONE HAVE A SET OF BRACKETS YOU WILLING TO SELL?
We sell the truck versions new in the catalog.
Okuma,
Chris is right,outer brackets work,inners from the burb do not..but can be easily fabbed,the are simply a flat plate with 4 holes drilled in it.. bolt your bumper up into position using the outer brackets and make a carboard template to make the inners..if you got a way to cut a little steel and drill some holes,it'll be no problem ;D
THANX LEADFOOT I WILL TRY THE CARDBOARD THING. ;D
