General Site Info => General Discussion => Topic started by: DnStClr on August 25, 2007, 11:54:30 am
I was cruising on Hotrodders.com and found a bit of useful info for finding vac leaks. The 1st two methods have been mentioned here before, but I found the bottom info pretty good for guys rebuilding an engine.
http://crankshaftcoalition.com/wiki/How_to_Find_Vacuum_Leaks (http://crankshaftcoalition.com/wiki/How_to_Find_Vacuum_Leaks)
I just made a powerpoint on vacuum & pressure. If anyone is interested in it either pm me your email address or post it here. Lotsa good stuff in there including tools and techniques.
Vile,
Very interested to see your power point!
ywaf1999@msn.com
Thanks!
Vile, you can upload it to this post if it isn't huge.
Chawk - sent.
I'd rather email it to anyone who wants it since I will be incorporating it into my curriculum once it's all said and done at which point it becomes copywrited material.
Thanks Vile! Haven't had a chance to check it out yet due to work...I'll check it out tomorrow.
Thanks again!
Chris
hello vile,
i would also like to see the powerpoint if it's still available.
gavila77@gmail.com
thanks
Me too please.
David@ProFastSupplyJAX.com
Much Thanks!
sent
yah, I'll take a copy if its not too much trouble.
oops
jay.tran@yahoo.com
Vile, if it is still available - I could use a copy too. I'm having a -_- time with my idle/fast idle/choke setup, it would be nice to cross vacuum problems off my list of suspects.
pbess@telus.net
With your idle problem 1st thing I would do is set your timing. Then play with the idle. Wait til it's cold and set up the fast idle and choke plate.
Thanks for the file Vile! I will definitely refer to it in the future. I got my timing set to 4 BTC as per air cleaner label, assuming timing tab is in the right place. My idle mix screws are 2+1/4 turns out, thing starts great cold, then dies almost as quickly without foot on the gas to prop it up. After propping it up for 45-60 secs, it will idle itself.
I have a dual delayed vacuum setup, as you probably assumed. Two pots on the passenger side, one I think is secondary lockout of sorts, the other is choke pulloff?
I suspect choke assembly, when I stick my finger in choke blades to open it - with engine off - it stays open, even when I push throttle open after. I have to push it back closed, and it doesn't seem to seal totally. Same when I push down on idle cam behind choke pulloff pot/fast idle adjust screw, it stays where it was pushed - until I push down on rod/close choke valve by hand.
When the engine is off, choke valve should be spring loaded and seal off completely - as the secondary air valve is?
If I pull a vacuum on my choke pulloff, the fast idle adjustment should contact and open the choke valve slightly byway of the linkage?
I realize now I should have put this in a different topic.....
Figured this pic might help some of you
(http://i6.photobucket.com/albums/y228/Sabaka454/vac.jpg)
Very interested to see your power point Ville! ;) okuma111@yahoo.com
They mentioned propane in the presentation. Holy smokes !
they? ;D
propane is very effective and safe just use the tool like the one pictured.
http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=THE382&source=froogle&kw=THE382
Please, may I have a copy?
jjszabo@comcast.net
Thanks,
Jeff
