73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 75 C20 on August 27, 2007, 09:17:13 pm
anybody tried one of these yet???
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=TMPRSBC&Category_Code=Thumpr (http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=TMPRSBC&Category_Code=Thumpr)
I had my sights set on one for a while...then I found out they are over $300.
it also doesn't included the roller lifters... And requires a larger stall and gears.
wellp- there goes that idea
I've read that they weren't "all that". A guy had said that you'd be better off getting a real performance cam rather than this "marketing gimmick". I agree, my custom grind cam for my 6.0 cost the same as that thumper. But isn't that thumper a retrofit cam - meaning you'd need $300 lifters and other required parts?
the cam is for the older non-roller equipped blocks, but that isn't anything new. It does required the roller lifters ($500) a full roller timing chain, cam button and a different ditributor gear.
