73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: Rockin77 on August 29, 2007, 09:13:12 pm
Title: Painting Leaf springs??
Post by: Rockin77 on August 29, 2007, 09:13:12 pm
Is it ok to paint my leaf springs on my truck with spray paint??
Title: Re: Painting Leaf springs??
Post by: FlatBlack77 on August 29, 2007, 10:10:28 pm
sure
Post by: bfofish on August 29, 2007, 10:19:53 pm
Better buy a case !  You will might have to repaint them allot. ;D
Post by: Blazin on August 30, 2007, 07:01:34 pm
If you are not planning on sandblasting them I would use a brush. I would also recommend a product called Chassis Saver. It is identical to POR15 but about half the price. Wire brush the heck out of or needle scale them, then brush it on.
Post by: okuma on August 30, 2007, 07:28:25 pm
ROCKING77, did you think spray painting your leaf spring would affect suspension?   OR hwy that question?     ------ I am just curious' ---- :-\   if you want you can even paint your tires and it will still be ok.
Post by: Rockin77 on August 30, 2007, 09:35:15 pm
I thought if i get it in the bushings or something that it would cause a problem. Sorry about the question i guess it was dumb
Post by: FlatBlack77 on August 30, 2007, 09:55:29 pm
I've done it.
Post by: elegy_c10 on September 06, 2007, 10:01:24 pm
I've done it.
me too...then i did a blue burnout
Post by: Blazin on September 07, 2007, 09:31:19 pm
No question is stupid, well almost no question. But if you don't know you should ask. Or just do it and see what happens.
Post by: jays2w87 on September 21, 2007, 09:26:32 pm
I ALWAYS paint my springs frame all that stuff. I advise is semi flat or regular flat black. looks awesome and hides alot! Unless you goin for a full restoration and you blasting them like mentioned above. Otherwise if you use a gloss or laqr paint you will see every little pit mark , dimple , and rust welt.
I also I'm guilty of painting a set of tires ....... They were white letter and they just didnt look right.... til I painted them.
Post by: bigblock73 on September 23, 2007, 09:25:46 am
I blasted my leafs and gave them an aerosol overhaul...turned out great!!
Post by: 1tonson on October 05, 2007, 10:42:29 pm
An old chassis guy told me years ago. that you should inspect and clean then spray on graphite paint. tractor suppy has it.
