73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: cougarkiller on August 31, 2007, 12:26:49 pm
Title: who makes the best drop spindle?
Post by: cougarkiller on August 31, 2007, 12:26:49 pm
exactly what the thread says. Are these hard on ball joints and stuff? I read somthing about you can only use factory off set rims with drop spindles? If i get a 3 or 2.5" drop out of the front how much do i need out of the rear to get it level of slighty raked? it for an 85 swb 2wd.
Title: Re: who makes the best drop spindle?
Post by: Captkaos on August 31, 2007, 02:18:56 pm
Any of them are good, I have used AIM, Belltech, Western.  The have no different effects on balljoints as stock ones.
How much are you planning on dropping it, only 3" in front, for the rear you need about a 2" difference to get it level, to get it raked some drop the rear about the same amount, so 3" or so.
Post by: VileZambonie on August 31, 2007, 02:20:33 pm
I use Bell Tech. I'm sure others are just as good since you see the same names selling them after all these years. One thing I've found with some wheels you may need spacers and to grind the lower control arm to get your wheels to clear. As far as your drop that'll be aprticular to your truck based on springs. Use a tape measure and just measure how far down you want it to go.
Post by: cougarkiller on September 01, 2007, 08:41:56 pm
what is the diff betweeb an axle flp kit and the drop hanger/shackle kit. Am I right if i say the flip kit is just the axle rides ontop of the springs? which is better?
Post by: Captkaos on September 03, 2007, 10:51:39 pm
you are correct, a flip just move the axle from below to above the spring.
Better depends on what you are doing.  If you want more less than 5" of drop, that eliminates a flip kit, if you want more then 5", you're better off starting with a flip.
Post by: mikeith on September 05, 2007, 09:31:16 am
i'm happy w/ my djm spindles! 3.5" drop in front. if your not in much of a hurry i'll sell you my 5" flip kit cheap in a couple weeks when we get mine bagged.... just ordered everything friday!!!! ;D
