73-87 Chevy _ GMC Trucks => Fuel Systems and Drivability => Topic started by: Dave Kay on September 29, 2007, 01:34:39 am
Title: New to the mysteries of the Quadrajet
Post by: Dave Kay on September 29, 2007, 01:34:39 am
First off I'd like to say that as a newly registered member on this site I've found an incredible amount of info here and it's Heaven sent... a sincere thanks to all for that. My current project (read that headache) is a 1986 GMC C3500 w/5.7 ltr "M" engine and a TH400. Bought it on a lien-auction for practically nothing but as things have progressed I've found more and more wierd problemms that cause money to go out of my bank account. I live in southern California where I'm attempting to get this truck smog-legal. However, it's turned out to be more work than I thought because the previous owner was a total hack.
The Big Mystery for me is with the Quadrajet carb/choke; on mine there doesn't seem to be one. Strange as this may sound, I honestly must ask what is probably the dumbest/newbie question there could possibly be; where is the choke supposed to be mounted? I'm talking about an automatic choke. On the carb body or the intake? The carb-guys I've gone to for over 10 yrs looked at my Quardajet that I pulled for them to rebuild and when I asked where's the choke (there wasn't one on the carb body) they replied it must be on the intake manifold. Ok I said and mentioned that there also looks to be some linkage that's missing too... can you guys scare that up? However, when I got back home later that day I looked and sure enough, there wasn't anything resembling a choke on the intake at all. Wondered if maybe a choke could be some kind of vacuum actuated thing... anyway, upon further review I see no choke assembly on the intake and no open holes where it might be mounted, nor is there a choke housing assembly on the actual carb itself... a mystery. Is the carb wrong or the intake? Or...?
Hopefully some kindered soul will take pity on me for my ignorance... and (gulp) help?
DK
Title: Re: New to the mysteries of the Quadrajet
Post by: Blazin on September 29, 2007, 07:12:43 am
Well I will give you a welcome from the other side of the country, New Hampshaa!
 I am just a lowly body man so I can't answer your carb question. Carb. and vehicle electrical are my low points. I can wire a house but not a car, go figure!
Post by: VileZambonie on September 29, 2007, 10:48:10 am
So I gathered you need a carburetor with a choke? Other than that I got lost reading your post... lol
You can buy a reman Q-jet electric choke for around $250 bucks from Autozone.
Post by: Dave Kay on September 29, 2007, 11:19:10 am
Thanks Mr VileZambonie and pardon my rambling... (YEEESH!) Revised the post this morn to make it understandable... too much Tacate beer does strange things to the brain in the middle of the night...
And so I can't figure out what I have here: a wrong intake manifold or a wrong carb? That's the mystery. Not sure I want to go the Autozone route justt yet because from what i can see under the hood there doesn't look like an electrical connection for a choke either... another point here is I'm pulling the intake because it's been determined  there's a leak at the head and so wondering if it might be easier to just locate another intake w/choke mounting hole... anyone know how the intake numbers affect model year, etc.,?
Post by: VileZambonie on September 29, 2007, 11:21:13 am
Wiring up an electric choke is a piece of cake.
Take a pic of the passenger side of the carb and the intake and post it here. We'll tell you what you have.
Post by: Dave Kay on September 29, 2007, 11:27:12 am
Roger that! Will post Monday when I get it back from the rebuilders, Thanks!
Post by: Captkaos on September 29, 2007, 11:38:39 am
The choke for a Q-jet is mounted on the primary side.  Yours if it is Computer controlled should look like this:
(http://www.carburetion.com/images/rebuild/4-477.jpg)
Non computer controls look like this:
(http://static.summitracing.com/global/images/prod/large/sum-210212_w.jpg)
Post by: Dave Kay on September 29, 2007, 11:01:43 pm
Ok, attempting to post image of passenger side of carb... let's see if this works....
Post by: Dave Kay on September 29, 2007, 11:15:48 pm
Cool, it worked! So as you can see there's some stuff missing on the carb like a vacuum pull-off for the butterfly and linkage for the choke coil assembly which, if you look closely, there isn't anything there below the carb body on the manifold. The other pic of the intake after I pulled it; Only an EGR header, and hopefully you can see the second view with casting numbers... any help on identifying this intake would be appreciated.. it had obviously been replaced on this truck sometime in the past. Will post carb pics when I get it back from the builder on Monday. Ciao~!
Post by: Dave Kay on September 29, 2007, 11:19:52 pm
OOOPS! here's the other view of intake showing passenger side w/EGR header.... ;D
Post by: Dave Kay on September 29, 2007, 11:24:09 pm
And by the way, thanks a heap for your pics CaptKaos, I can now see what my carb is missing...
Post by: Dragon on September 30, 2007, 12:49:54 am
Dave, looks like someone has replaced your Carb with a Non-Computer/Electric Older one that doesn't have a Choke.
Your '86 should have one that looks like the one I have on my '82 Olds Cutlass Wagon(If not a Manual Carb mounted Automatic Choke, which still looks like the pic, but minus the electrical connector to the side of the choke).
Not My Carb Pic, but looks like it.
(http://memimage.cardomain.net/member_images/12/web/2244000-2244999/2244133_2_full.jpg)
The Round Object on the Left with the Connector going to it, is the Electric Choke, and the Vacuum Canister infront of it, is the Choke Pull-Off Valve.
1980's Electric Carb, with Automatic Manual Choke:
(http://www.cliffshighperformance.com/images/qjet_history_5_A_thumb.jpg)
Your Current Carb, is the exact one I have on my '77 GMC, it is refered to as a '74-77 Quadra Jet Model 4MV with an Automatic "Divorced"(Means has a small choke mounted on the Intake Manifold and connected to the Carb via a rod).
Personally I prefer the Non-Electric Quadra Jets, for their ease of rebuild, but it looks like I have to add an Automatic Manual/Electric Choke, like you may want to.  :-\
Post by: Dave Kay on September 30, 2007, 12:34:46 pm
Thanks for the pics Mr. Dragon, the carb has been out of my hands since Thursday when I took it to the rebuilder but I believe it looks more like the second pic posted by Captkaos (the '80's non computer controlled) with mine missing the vacuum pull-off(s) along with the linkage for the butterfly... the jury is still out on this because I haven't heard back yet from my guy doing the rebuild... talked to him Sat and he's aware of the problem.
Haven't broached this idea to my rebuilder yet but am wondering if I can't just put a manual choke cable on it and go with that? Problem is, all the aftermarket choke/cable setups I've seen so far look like they install on an existing electric choke setup that is mounted on the carb-body, not on the intake... anybody ever try this on their rig?
Post by: Dave Kay on September 30, 2007, 12:39:14 pm
And by the way, does anyone know where I can get info on intake manifold casting numbers? Year? Application?
(see my previous post)
Thanks
Post by: VileZambonie on September 30, 2007, 08:06:44 pm
It's a mid 80's 305 cast iron 4 bbl manifold. It's a boat anchor. Your best bet is to find another electric choke carb.
Post by: Dragon on September 30, 2007, 10:21:29 pm
I agree that you don't have an Electric Carb, just was pointing out that your truck should have came with one, and your current Carb was swapped like the Intake Manifold.  By the time your truck rolled off the assembly line(Actually more like 1981/82 when Pickups/Vans/Suburbans recieved the Modified Q-Jets), Electric Carbs and Chokes were Standard Equiptment  Thanks to the strict Federal Standards.
Seeing that you lived in Kalifstonia, I wasn't sure if you still have to do any Emission Testing or Not??  If you do,  just figured that you might want to know what should be on there or not....
Post by: Dave Kay on September 30, 2007, 10:24:15 pm
Wow, no kidding... a big thanks for looking that up and too bad I sold the boat.
Actually, I've been thinking that buying another intake would be better than buying another carb because mine went to the rebuilder last week and I got $$$ bucks into that. Been going to those guys for over 10 years and they're about the best in my area, so I have faith that at least it's proper for my year truck. As far as I can see, the only parts missing on my carb now are the vaccum pull-off for an intake-mounted choke and the linkage... those can't be THAT expensive? (cringe)
Looked at the Weiand 8000 spreadbore w/EGR and choke riser and they're 50 state smog legal, around $155 online. What is the collective opinion on aluminum intakes? How do they hold up for the long run? Warp, leak problems? Or should I go with another cast iron intake? Not really giddy about buying USED iron (or alu) but wondering if by now anything NEW isn't all made in freakin' China... (my American problem)
A big thanks again!
Post by: Dave Kay on September 30, 2007, 11:39:20 pm
Thanks for that info Mr. Dragon and YES--- The People's Republic of Kalifstonia surely does have emmisson testing and in fact, The Comissars keep screwing around and changing the standards (laws) every few years so as to eventually "outlaw" older vehicles like ours... coming soon to theater near you! WAKE UP AMERICA! (Dang it now, get me off that podium already...)
To respond to your post; when I talked to my carb rebuilder he told me that as long as a vehicle has all the required FED/CA emmision do-dads in the right places and plugged in, the STATE-SPONSORED-SMOG-DEAMON-BORG who has the power of life-or-death over your vehicle, only looks, and then gives you a visual PASS or FAIL. Then, if you passed that he puts the sniffer up the tailpipe and runs his evil machine... accordingly, he does NOT pull the air-cleaner and look for carb numbers, choke assemblies, manifold casting numbers.
Having said all that, I would like the truck to get thru smog test on the semi-annual basis without a hitch and not have to hassle with all this stuff again. So I put my faith in my rebuilder's info because he's got my old '77 Chevy 292 (another project-truck) thru the system for over ten years now and he's one of the best... however, I do welcome all second opinons.
Thanks for your input but at this point I think I'll be alright with a newer intake (w/thermal choke) and my current carb... (your opinon on Weiand aluminum intakes would also be appreciated)
I should also add that according to the California State Department of Motor Vehicles, (SIEG HEIL!) this truck was last registerd in 2004 and passed smog-test... ah!---the mystery!
Post by: Captkaos on October 01, 2007, 10:52:23 am
Dave, as Vile said the intake is not worth saving.  If it is allowed (I live in Alabama so I don't have emissions) I would put a Spreadbore Aluminum intake on it.  Just get one that is for idle to 5500rpms and in dual plane and you should be fine.  Historically I use Edelbrock...
BTW please keep in mind this is a family oriented site when posting.
Post by: Dave Kay on October 01, 2007, 12:11:10 pm
Yes absolutely Capt--- family-oriented and will definitly comply. Apologies if my cultural satire went over-the-top or offended anyone.
On the spreadbore aluminum: I'm in agreement on chucking my old intake but looking online for something smog-legal to replace it I couldn't find anything from Edelbrock w/EGR riser, only came up with the Weiand 8000, and that looks like my only option... unless anyone knows of something else?
You guys have no emmision standards? Wow, I envy you 'Bama boys! Thanks again for your input.
Post by: Captkaos on October 01, 2007, 01:28:11 pm
thanks Dave.  The Edelbrock EGR version is PN 3701
http://store.summitracing.com/partdetail.asp?part=EDL%2D3701&autoview=sku
Weiand 8000
http://store.summitracing.com/partdetail.asp?part=WND%2D8000&autoview=sku
Summit version:
http://store.summitracing.com/partdetail.asp?part=SUM%2D226017&autoview=sku
GM Performance:
http://store.summitracing.com/partdetail.asp?part=NAL%2D10185063&autoview=sku
Post by: Dave Kay on October 02, 2007, 12:07:55 am
Weiand 8000
Summit version:
GM Performance:
Wow, thanks a whole bunch for that post CaptK, looked at all those intakes and drooled alot... but darned if I couldn't get the same results at Summit as you did... prolly cause I added the actual vehicle make to the query; 1986 GMC C3500 5.7 'M'.... Using that it only returned the Weiand 8000. Try that and see what you get? Anyway, just as well because here's the Official Word from The State of California as to what I can "legally" install on my truck--- scroll to the bottom of that page;
http://www.arb.ca.gov/msprog/aftermkt/devices/aftermktdevice.php
you might also notice the Holley there too towards the bottom of list, but it's a square bore, no can do. Hope that Weiand is a good-for-the longhall setup and thanks again for your all your help and a ton o' thanks to all who posted their advice too... looks like this stage of the project is in the bag. How do I PayPal you guys to become a supporting member?
By the way, I never did get any opinions here on aluminum intakes... vs. iron that is.
(edited) ooops, that link didn't work... see waht we gotta' deal with out here... lol
Try this and go to After Market Parts Sold in California than go to After Market Parts Data Base and look at intakes...
 http://www.arb.ca.gov/msprog/aftermkt/aftermkt.htm
Post by: Captkaos on October 02, 2007, 09:25:08 am
I thought that is what we were talking about aluminum vs iron.  Which is why we both said the factory iron intakes are a boat anchor.
I only looked up Emmissions equipped intakes that had the EGR.
If you would like to send a donation, you can send it to webmaster@73-87chevytrucks.com.
Post by: Lt.Del on October 02, 2007, 10:50:55 pm
I have the edelbrock 3701 (w/egr) on my   383 stroker (http://www.delbridge.net/install) and it does great for me.
(http://www.delbridge.net/carb6.jpg)
Post by: Dragon on October 03, 2007, 02:32:33 am
My Apologies as well for stirring the Pot to Get Dave Riled! Didn't get a chance to read our post before it was edited, but I too get frustrated with my State's Policies on Older Cars/Trucks, so I too get on my Box from time to time ;D  I have friends and Family in Kalifstonia, and they tell me that they get an Evil Eye, if their Air Clear Wing Nut isn't facing the right direction at the Test Stations they go to ::)
So far my State no longer test Cars/Trucks over 20+ yrs, but have been talking about doing the same as Kalifstonia, to keep/increase State Revenue.  Ofcourse with them cutting down on the City Parking, and Gouging you with the fees to park in the Available Spaces.   Here is a bit of retarded logic for you, my County and Surrounding Areas make a pretty good profit from Gas Taxes,Licensing and Emissions Testing Fees/etc, yet they are cutting down on parking in the major areas, and placing fees on available spaces making it even more difficult for those who can barely afford to drive. ???
I am leaning towards a GM Performance Aluminum Intake myself(same as Capt posted a link to), as try to use pieces that would be State Emissions approved just incase!  Aluminum Intakes have come along ways in durability and performance wise, you just got to remember to use a good gasket set/and silicone sealer, follow the Bolt Pattern, and Torque to proper manufacturer specs to keep the chance of warping to a minimum(Really what you should do with all Engine Parts, Aluminum or Factory Cast Iron.).
Also if you don't have a Intake Thermal Choke as of yet, Brothers has these available
http://www.brotherstrucks.com/products.asp?dept=467
'69 is the Newest they have listed for a Small Block, but I don't why it wouldn't work for a '73-91 Pickup/Suburban/Van if so equipted(May get one myself, if I can't add a Choke to the side of the Freshly rebuilt Quad on my truck, and if I get a new intake) ???
Post by: Captkaos on October 03, 2007, 09:25:27 am
You can get those chock setups from about any parts store.  I know Napa had one.  They won't work on the later models though as they were electric chock and the 87-91's were TBI.  I am guessing you were talking about using it on a non-stock intake for the application?
Post by: Dragon on October 03, 2007, 04:46:05 pm
Yep Capt, both Dave and I don't have Carb mounted Chokes on our Trucks(mine has a Rebuilt Quad, but I believe the previous owner got the wrong one back from his rebuilder), so if either of us use a different manifold, we would need a new Thermal Choke like the one I posted/Napa carries.
Post by: Dave Kay on October 03, 2007, 09:16:26 pm
What was it I said earlier about "this stage of the project is in the bag." ?~@#%?!!
Well, I've learned a lot from this forum as well as my local souces but still a lotta' questions in my mind... and after a long day "under the hood" cleaning, scraping, etc., I consulted my carb rebuilder about those new aluminum intakes (which would be legal) but he says the old iron intake is good to go and I should just install it, choke or no choke... more about that later...
He also says that he doesn't believe the old iron is a 305 intake either--- personally I don't know---- and not to insult Mr. Vile's integrity, but my rebuilder is asking how that info was aquired... I've searched all over the net and came up w/nuttin' as far as casting numbers. Did happen upon a really good site though: http://www.mortec.com/castnum.htm Maybe you guys have seen it before.
As far as the choke, thanks for that Brother's link Mr. Dragon, and if I were to get the new Alu intake, those thermals would surely be the ticket. But I'm undecided on intakes now. To further uncloak this mystery, the local Chevy dealer dated my carb, and get this--- as pre-1973! Yikes! Back to my carb rebuilder: he says he'll install a manual choke cable if needed, install leaner jets, route vacuum lines to carb ports, and get the thing through smog come heck or high water. He also says to save my money by NOT buying another intake because 2 years from now if I need to get a smog-test from any other shop (should that need ever arise) I'll have to find the proper/year carb--- w/electric choke... that was already in my plans but just a quick search for a re-buildable core looks to already be a tough-nut!
I should also mention that of the three local parts houses that I trust, all of them poo-pooed the idea of getting one of the "boxed" remanufactured carbs because they're all leakers--- big time! This set me back a notch, but they say the reason they leak is because they sit on the shelf for so long that the seals dry out and people return them constantly... anybody heard that before?
Post by: Captkaos on October 04, 2007, 09:41:36 am
14057055 PN is a SBC manifold found on 305's or 350's.  It is still a cast iron hunk of metal and does nothing for making power.  Which is why we suggested getting an aluminum one.  If you don't mind the current setup, there isn't anything actually "wrong" with it.
Have seen Mortec, but I use nastyz28 for internet searches on PN.  You can also get the book Chevy by numbers or something like that.
Looking back on your orginal post you stated the truck was a 3500 (1 Ton) technically these were emmissions limited from what I know about.  BUT for the carb, I see no problem getting a carb from the parts store for you application.  I just sold one I used on my Jimmy for a while, didn't have any problems with it.
If you want a good shop, try http://www.thecarburetorshop.com and ask them about you application.  They have a reputation for doing a great job on rebuilding them and sometimes have them in stock.
Post by: Dragon on October 06, 2007, 02:11:02 am
Yes I used to work for one of the Local Parts Stores, and I can vouch that quite a few of the boxed Carbs would leak after sitting on the self for awhile!  Of course to remedy them sitting on the shelves for too long, our Stores made sure to have enough of them out on the floor to be easily seen by Customers.  That idea was great in that quite a few of them made it out the door at many locations, the downside was that not many made it to the registers before hand(We're talking $300-$600 Edelbrock and Demons) ::)
For when you do find a rebuildable core and are looking to have a Performer and Emissions Approved Q-jet, I would check out these guys!
Sean Murphy Induction:
http://www.smicarburetor.com/
Sean's around my age(31 give or take), and he knows how to Rebuild Carbs like no ones business! He's also in Kalifslavia, so he knows abit more as to what you can or can't do in The Peoplez Republik 8)
Cliff's Highperformance Carbs:
Cliff literally wrote the book on "How to Rebuild, and Modify Rochester Quadra-Jets"
Post by: Dave Kay on October 07, 2007, 12:28:40 pm
Thanks for the links CaptK & Dragon, et al... you guys are awesome, awesome awesome!
