73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: gpday08 on October 04, 2007, 02:54:02 pm
now, have some questions, im planning on the kit from to lower 2 1/2 front and 4 rear, how is this done in the rear, is there any frame cutting involved? i understand the front, im getting the drop spinles, not springs so i just need info on the rear drop! thanks!
It's probably shackles and hangers for the rear
4" rear is shackles/hanger. It will require removing the rivet holding the hanger on. Use either a grinder or air hammer.
I can get you a 2.5/4 kit for your truck for $445.99 + shipping.
Air Hammer might be a bit easier then the grinder. I used a grinder on mine and it took a bit to grind. What I ended up doing was grinding a good flat spot on the rivet and then drilling it out. Went trough a few bits, but got er done!
Chris, does the kit you sell come with shocks also?
The 2.5/4 kit uses stock shocks, they are not included.
