73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: Hook on October 12, 2007, 07:18:44 pm
I want to lower my 2 wheel drive 78 burb. It has a 454 and is 2500 series w/ 8 lug wheels. Looking for the most economical way to do this. I haven't owned this long and actually haven't even looked at the suspesion in detail. Cut front springs or use SB chevy springs? Blocks work in the rear or is it SOA? I have alot of experience doing all my own mechanical work so tools are not a problem. This is a 3rd vehicle and only used to tow a trailer occassionally and haul our 3 large dogs to the beach, etc.
(http://i28.photobucket.com/albums/c201/JEFFs_Stuff/Big%20Tow/78GMC1.jpg)
nice Sub'. at first glance i thought you had a satellite dish on the top because of the basketball hoop.
you could cut the coils up front. I think one whole coil will lower it two inches. and you could take some leafs off the back but I don't know how well it would work for towing anything.
Drop Blocks for Rear(Says Lift, but are Universal between the two.).
http://www.performancecenter.com/product/Lowering+Kits+%26+Handling/Blocks/0/4/0/GMC/1978/Suburban+3%7E4+Ton/Vehicle+Specific+Blocks
As for the Front Springs, your Stock Springs would have sagged enough over the years, so I would start out removing 1/4-1 whole coil(Only do a little at a time).
SBC Front Coils won't be able to properly handle the weight of the 454, and you would get an additional un-wanted sag to them.
Block on the rear will LIFT a factory Suburban. Factory setup is SOA.
The big question is How much you want it lowered?
Options for the rear is shackles and hangers or a flip kit.
Options for the front is drop springs (or cutting 1/2 coil off) OR convert it to 1/2T setup and use 1/2T HD spindles.
SBC springs will hold a 454 ( I used them for 10 years), there is no difference in aftermarket springs concerning BBC vs SBC for drop springs. Using SBC springs will drop it about 1".
I would go drop spindles in the front and shackles in the back or don't even bother. You'll ruin your ride quality and towing capacity cutting/eliminating springs
You're right, Sorry I was thinking that the rear was already over the springs like a car.
BrothersTrucks.com has a 3/4 ton drop spindle.
Thanks guys. I will proably go with the dropped spindles since I only want to do it once. I want a drop something in the range of 3" in the front and probably 2-2.5 in the rear. Once I get moved and have a garage to work in. Need it to tow my Camaro to Vegas.
