73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: 79SHORTWIDE on October 28, 2007, 11:24:02 am
Thinking of running 18's on the back, 17's on the front of my 79 shortwide.
Has anyone run a wheel wider than 10 inches in the rear without leaf spring interference issues?
I don't mind "tubbing" the existing wheel tubs but I'm not getting into relocating my springs inside the frame. I've already lowered it 3/4 with spindles, hangers and shackles.
I'm after the deep look on the rear.
I think these are what I plan to buy. (http://i23.tinypic.com/xn6k9g.jpg)
It has been a while since I have measured one out, but see if you can get a 10" wide wheel with about 5" of backspacing and mount it (without the tire) on the truck and measure you clearances. Each truck will be a little different, but you need at least an inch of clearance on the inside and outside for suspension travel. You should be able to fit a 12" wide wheel in there though with the right backspacing.
That's kind of what I was thinking. The fun part is getting the wheel I need to take the measurements. most places don't want to "loan" one out. Thinking of that Percy's wheel'tire fitment tool. It's 80 bucks but probably worth the $$$$. Thanx for your input.
You can actually make yourself one of those with a piece of thin board. Just cut it in a circle at the diameter of the wheel you want and mount it to the hub.
See, this is with a stock wheel that I am assuming is 8 inches wide. The tire size is 295/50/15.
I'm thinking I GOTTA GET MORE tire in there! ;D
(http://i21.tinypic.com/23ks16r.jpg)
I'm sure somebody on this site has done this....18x10 or 18x12 on the rear.....shout out, give us the answer ! (and tire size you used). I want a fairly tall tire to help fill the wheel well. Needs to like like the one I have posted earlier on this thread.
I think Vile has 305 or something like that. You should be able to get a 12" in there...
I'm hoping...
The only real issue I can see is that there may be a problem with the E-brake cable with a deep offset wheel. It may hit. That and the fact that wheels and tires of that size cost so much ! :'(
start saving!! ;)
