73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: zieg85 on November 26, 2007, 06:44:55 am
Can anyone date these center caps. They bolt through the backside.
Is the bolt pattern 5X5? If so I would guess 73-77. 72 down was 6 lug on 2wd trucks and van I believe?
72 on down was 6 lug if it was 4 wheel drum brakes. If you had disc up front it was 5 on 5 just like 73 on up. I know it is early to mid 70's, just don't know when they went to the bolt on from the outside.
From the trucks I have messed with, I have only seen those on a 76 and under truck/van. Had a set floating around the farm from a 76 G20. I like them better my self, cleaner smoother look.
Thanks for the reply. Merry Christmas
Those are exactly what came factory on my 77 with the rally wheels. I havent seen many others with the same color center
Thanks so it would be safe to say 73-77? I only have 3.
