73-87 Chevy _ GMC Trucks => Performance => Topic started by: mickey on December 03, 2007, 06:48:33 pm
Title: 350/305 help
Post by: mickey on December 03, 2007, 06:48:33 pm
trying to find out a way to visually look at a 305 or a 350 and know what you have.
Also any other ideas on how to figure out what motor i have in this truck.
It is a 86 4x4. the guy i bought it from swears it is a 350. but then he is defently not the sharpest knife in a drawer.
Thanks for any help in advance
Title: Re: 350/305 help
Post by: Captkaos on December 03, 2007, 06:49:54 pm
Pull the engine code off the engine.
Post by: Lt.Del on December 03, 2007, 09:52:01 pm
Look at the starter bolt pattern.
350-off set two bolts--one in front, diagonal from the other.
305--two bolts in line paralell with the end of the block.
Post by: eventhorizon66 on December 16, 2007, 09:19:45 pm
I pulled the starter off my old 305 and bolted it to the new 350 Goodwrench motor I put in this summer.  Both offset style.  What's up with that?
Post by: baggedk5 on December 26, 2007, 09:36:35 pm
Cant really go off the bolt pattern of the starter. pull the casting numbers off the block, behind the driver side head. Goolge the numbers, "chevrolet casting number 3970010" for example. Usually you can gather motor c.i info, yr, and vehicle it was factory in. using the other casting numbers and marks, found various other places on the block, you can get the manufactured date, and plant info.
Post by: 87GMC2WD on December 31, 2007, 09:07:21 am
or if its the original motor check the sticker that has the emissions on it and it should say either 5.0 or 5.7
Post by: 84chevysilverado on November 16, 2008, 03:45:10 pm
heard sowhere that on a 305 the dipstick is on the passanger side and a 350 is on the drivers side.
Post by: VileZambonie on November 16, 2008, 06:12:01 pm
This is a pretty old post but the info you were given is wrong.
