73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: gpday08 on January 03, 2008, 01:34:15 pm
where can i get rear disc conversion kits for my '79 c10??? any help is appreciated!!
Here's a kit from Stainless Steel Brakes Corp. Rear Standard Disc Brake Kit (http://www.stainlesssteelbrakes.com/products/detail/500/?make=Chevrolet&model=Silverado+1500+%282WD%29&year=1979) I've heard that unless you tow heavy loads, rear disc brakes on a truck don't offer much additional braking performance. Still tempted to try them myself, though.
Also your proportioning valve should be converted over to the disc/disc type. Or you could get an adjustable valve.
I would strongly encourage the use of a master cylinder designed for rear disk brakes as well..Drum MCs keep a little bit of pressure on the rear brakes, to keep the shoes closer to the drums. Using the drum MC will cause your rear brakes to drag a little bit.
Also need to use a different proportioning valve.
Lots of information on rear disc swaps on Coloradok5.com. Lots of the 4x4 guys do these swaps.
I am in the middle of putting rear discs on my 1 ton crew cab. Using DIY4X.com rear caliper brackets, 77 Eldorado e-brake calipers, 3/4 ton front rotors. FWIW I have about $400 in the set up with ALL brand new parts. MUCH less than some of the kits.
Read this write-up... http://www.73-87.com/7387garage/chassis_suspension/reardisc.htm
THANKS GUYS
(Here is mine just to add some thing to the tread) I got the DIY4x.com brackets on the truck. Just for reference these are Eldorado calipers, 3/4ton front discs and DIY4x.com brackets. I still have to make all the lines.
I also got the Detroit Locker in. Looks like we may have a working rear axle again soon.
Couple of quick pics for fun.
(http://a202.ac-images.myspacecdn.com/images01/7/l_18e5f66bd2e560c08bd2c6df86296161.jpg)
(http://a695.ac-images.myspacecdn.com/images01/80/l_0665a5a3c0b6cf38fc3bba9f830591f6.jpg)
That is the same exact jack I have extemjeepn...good to know that it can support a 4x4! I was concerned about it's ability to hold up my lowered 74.
Haha, I have had that little jack for a LOOOOONG time. Still works, but to be fair there is no bed, rear bumper, exhaust on that truck right now. ;D
