73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: low79fx on January 18, 2008, 07:59:27 pm
Need help with a Chassisworks prostreet 4-link.Has anyone ever installed one of these setups? Does any one have specs for this setup?Saw cubicdollars posted he had one,does anyone know if he's still a member?
I just replied to your PM but if anyone else is interested here is the artical I used. http://www.cachassisworks.com/Stories/HowCAC-009_WEB.pdf (http://www.cachassisworks.com/Stories/HowCAC-009_WEB.pdf)
Good Luck
It does help,I had already ran accross this article,it is very informative.But I was wondering if you could give me the tube length mearsurements.I am fabricating a kit similar to the one installed.Need length of top and bottom tubes from edge of tube to center hole of bushing at welded rodend.Please reply!!!Thanks low79fx
Any updates on you 4 link install ?
cubic how did yours turn out? Where did you buy your set up from? Did you ever make a post here on it? I can't remember. I'll be doing mine down the road but am considering air ride
Hey Villa I have had my 4 link in for over 10 years but as soon as the dually is done I am going to get back on my stepside. I am looking for a 9" ford rear end with disk brakes to Narrow. I already have a set of 15 X 12 convo Pro's for it. Here are a couple of picts.
Cubic, I see your hunting a 9" & disc brakes. The ideal set-up I feel if your wanting to match the GM truck front bolt pattern is this: Get any 9" housing, Get the rear brake set-up off of a '90's Caprice/Impala, When you have the housing done buy the ends that except the 3.150 bearing w/ the GM car backing plate pattern, The axleshafts will have to have a 1/4" longer "set-out" to match the GM distance, The wheel bolt pattern is the same as the trucks & you get modern brakes for a vehicle of similar weight & you can buy parts at any local store. They have the built-in drum inside for the E-brake. Just a thought, Lorne
Thanks For the info I think I know where there is a junked out caprice ;D
That is a clean bed, you did a good job on the wood work. ;D
Hey guys,want to post some pics but don't know how? Can some one help?
(http://a359.ac-images.myspacecdn.com/images01/95/m_ff0e3b2dcd6e4ca74cd79457e2b52e86.jpg)(http://a222.ac-images.myspacecdn.com/images01/125/m_a78259c99392848b3865700a0b2434ed.jpg)(http://a367.ac-images.myspacecdn.com/images01/109/m_653df4d403725fc4990fe942e4f2b6c6.jpg)(http://a357.ac-images.myspacecdn.com/images01/120/m_920bc12da203c2b0e82f6438cc6d5b2c.jpg)(http://a242.ac-images.myspacecdn.com/images01/74/m_fb9911b1a09be22cc4d5acd8d6264c79.jpg)(http://a84.ac-images.myspacecdn.com/images01/124/m_4d124a2811a19b68afe2fbfa2afed9e3.jpg)(http://a332.ac-images.myspacecdn.com/images01/92/m_50f46af0f7308c8e2eb86315ed239b53.jpg)(http://a944.ac-images.myspacecdn.com/images01/113/m_6f7392b0238e7960a60f4ca02e6aac47.jpg)(http://a932.ac-images.myspacecdn.com/images01/124/m_854e1b1675ba0ef2b8b13988ee4a00f3.jpg)(http://a654.ac-images.myspacecdn.com/images01/82/m_bc0a8f80a14eeb6490cb0f5d07a07e7d.jpg)
check this out, all fabbed at home , with exeption of coilovers.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6428.0
