General Site Info => General Discussion => Topic started by: Redneckchevy on January 20, 2008, 02:42:23 pm
Title: Aftermarket Fans
Post by: Redneckchevy on January 20, 2008, 02:42:23 pm
What would be the benefit of a After market cooling fan? like one of them 70$ ones from summit?
Cpl degrees cooler then stock or is it just for looks?
Title: Re: Aftermarket Fans
Post by: VileZambonie on January 20, 2008, 03:15:41 pm
The main benefit is thermal efficiency/consistency and lack of mechanical drag on the crankshaft. Unfortunately the only real bolt on high efficiency fans for our trucks are around $500 bucks. A 16" fan alone with no shroud will not proved adequate cooling
Post by: Redneckchevy on January 20, 2008, 03:35:58 pm
well i found one..Fits perfect in the shroud in place of the old one  guy wants 15 bucks for it like new condition not warped or nothing
Post by: jonkmbll89 on January 20, 2008, 03:44:13 pm
Sounds like a good deal. I would love to put a dual setup on my 85 c10, but like Vile said they are pricey. :(
Post by: VileZambonie on January 20, 2008, 04:51:19 pm
If you can mount one effectively inside your existing shroud then go for it! Just make sure you wire it up using the correct gauge wire, circuit protection, and a relay controlled by a thermostatic switch.
Post by: 86swb on February 01, 2008, 08:19:32 pm
$15.00, I say go for it. Just make sure it does work.
