73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: greenmonster on January 21, 2008, 11:44:47 am
Title: 203 shift problem
Post by: greenmonster on January 21, 2008, 11:44:47 am
My 203 won't shift into hi-loc.It shifts into low-loc,low,neutral,and hi.
Title: Re: 203 shift problem
Post by: KojaK 79k10 on January 24, 2008, 03:06:28 pm
first thing i would do is to check your linkage and manually shift the linkage if possible. when did this happen or has it always been this way. what is it in (1/2 or 3/4 ton) have you ever serviced it? ie.. oil..
Post by: greenmonster on January 24, 2008, 07:57:24 pm
It is a 1\2 ton.It just started this 3 months ago but I fixed it.I took the shifter boot off and the little cover off that was over the shift linkage and lubed it up.It shifts better than it ever has.Thanks for the reply.
