73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Redneckchevy on January 21, 2008, 11:39:52 pm
Just wanting some input....Flex fan with no clutch or stock fan with clutch?
Got a Electric fan for my chevy...And was thinking about replacing my other trucks stock with the Flex fan from the chevy....Now i got the chevy with the flex fan..so i dont no if it robs power or gives power...What do you guys think? ???
Flex fans can come apart and do some real damage. Search the web on flex fans to see what I mean. I do not like flex fans. Either go with regular fan with clutch or electric fans.
The stock fan with a clutch is MUCH better, cools better and uses less power...
Vile...What do you say about your fan on the 454?
Older flex fans were very prone to cracking and flying apart. When I first put my posi in my 74 years ago I went to do a burnout and all of a sudden BOOM and the truck started shaking like CRAZY! I quickly shut it off and opened the hood. The fan had sent a blade through the schroud, through both layers of the steel hood and the blade landed in the middle of main street about 150 feet away. Prior to that I was under the hood reving it up. Luckily it didn't take my head off. :o Flex fans are much better quality now and work very well but can be noisy. They provide less drag which you will notice right away if you have a heavy clutch fan hanging on the front of your water pump now. The downside like I said is they can be a lot noisier than your clutch fan. Don't ever use an old flex fan and if you've had one on your truck for a few years, periodically check it for loose blades or cracks around the rivets.
On my 74 for now I have a flexfan until I decide exactly what I'm going to do for an electric fan... I drew up a schematic for someone on here a while back to give you an idea of how easy it is to wire one up.
(http://i6.photobucket.com/albums/y228/Sabaka454/Fanrelayckt.jpg)
