General Site Info => General Discussion => Topic started by: GUILLERMOARIAST on February 28, 2008, 07:32:56 pm
Title: loose shift lever
Post by: GUILLERMOARIAST on February 28, 2008, 07:32:56 pm
Hello, my 4x4 1980 Blazer has a mechanic gearbox. The problem is that both shift levers are loose, they have a slight movement in every position, including neutral.
My mechanic told me this is normal, but i doubt it.
What do you think?
Title: Re: loose shift lever
Post by: VileZambonie on February 28, 2008, 07:41:20 pm
what transmission do you have? Check the linkage
Post by: Captkaos on February 29, 2008, 12:32:06 pm
If it is a manual 4 speed, they are loose, the t-case shifter can be considered loose, but you can adjust it some...
