General Site Info => General Discussion => Topic started by: bigtee72 on March 07, 2008, 07:35:11 am
Title: Alternative lift options
Post by: bigtee72 on March 07, 2008, 07:35:11 am
My buddy has an '89 chevy s-10 blazer. He wants to raise it 2". I told him the proper way was a lift kit. He wants to know about 2" blocks in the back with longer U-bolts, and cranking up the torsion bars in the front. All this just to fit 31" tires with aggresive tread. Any thoughts would be most helpful.
Title: Re: Alternative lift options
Post by: Captkaos on March 07, 2008, 09:50:11 am
I am moving this to general discussion as this is for fullsize Blazer/Jimmys, but I don't think the ride would be that good if you turn up the torsion bars.  I wouldn't think that would be enough lift for 31s on an 89 S-series Blazer though.  Never had one...
Post by: VileZambonie on March 07, 2008, 10:14:26 am
He can max out the torsion bars but better replace the mounts because they will break.
Post by: bigtee72 on March 07, 2008, 10:49:53 am
Are you talking about the torsion bar supports?
Post by: red4wd on March 07, 2008, 11:19:57 am
You can get indexed torsion bar "keys" for most applications that will give you a couple inches of lift.
Here is a link http://cgi.ebay.com/ebaymotors/eBayISAPI.dll?ViewItem&item=180220317959
Post by: VileZambonie on March 07, 2008, 04:57:23 pm
Yep, there's an updated design. If you have the original design on there and crank up the torsion bars I gaurantee they will break
Post by: k5blazerfan on November 24, 2009, 06:39:37 pm
Dont mess with the torsion bars gives ya a junky ride.... id put in a 3 inch body lift and you should be good to go...
Post by: beastie_3 on November 24, 2009, 08:59:44 pm
Im not sure about the s10, but I know there are places to buy new torsion keys for the full size trucks. It gives lift while retaining the stock ride. I used to sell them at my old shop. Full Throttle Suspension used to make them. See if they are still around.
Post by: 1980c10 on November 24, 2009, 11:39:09 pm
a body lift would probably be the easiest good solution. he could trim the fenders too. i had an 86 s10 blazer with no lift, my tires were 29.5 tall, i forget the actual size though. they fit.
Post by: Captkaos on November 25, 2009, 11:22:32 am
This post is almost 2 years old....
Post by: team39763 on November 26, 2009, 03:06:51 pm
HAHAHA...bringin' it back from the dead huh?
I cranked up the torsion bars on my 94, but I'm gonna go ahead and put in some of the updated lift keys.  I stuck a set of 31's on it and it only needs minor trimming on the rear of the fender lip.  I wanted to put a 3" body lift on it, but people said the 94 was different from all other years and I might have to get steering shaft extension and oil line extensions(?) and I needed a 94 specific kit, so I decided to just crank the bars up a little more.  They're not maxed out though.
Post by: team39763 on November 27, 2009, 05:12:11 pm
Here's a pic of my S10 with the t-bars cranked a little and 31" tires on 17" ZR1 wheels.
(http://i46.photobucket.com/albums/f143/team39763/th_101_0202.jpg) (http://s46.photobucket.com/albums/f143/team39763/?action=view&current=101_0202.jpg)
