73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: chevman1979 on March 10, 2008, 10:51:27 pm
Just recently swapped out my bad th400 with a th350. It bolted right up, but now I'm having driveshaft problems. the th350 i got is a 9inch tail shaft, so its a bit longer then my th400...i was gonna have the driveshaft shortened but the u-joint sizes are different. My existing u-joints are 1.25nch dia. the yoke for the th350 are 1 inch dia. Do i need to get a different driveshaft to make this work???
1979 chevy c20 2wd
350 5.7
You should be able to order a u joint with two caps one size, and the other two caps the other size.
kool!...i didn't know they made those...thanks
I just did this here
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7334.75
