73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 75 C20 on March 26, 2008, 08:16:12 pm
Title: 327
Post by: 75 C20 on March 26, 2008, 08:16:12 pm
is there anyway to tella a 327 from any other small blcok just by locking at it?
Title: Re: 327
Post by: VileZambonie on March 26, 2008, 08:21:12 pm
The casting # on the block can help but to be honest, other than seeing the crank... no sure fire way to tell unless it's an early small journal 327
Title: Re: 327
Post by: 75 C20 on March 26, 2008, 08:25:33 pm
it would be a 68 if it is one sooo???
Title: Re: 327
Post by: frogman68 on March 27, 2008, 02:40:55 am
My casting number was used on 302's 327 and 350's so if you arent sure if the engine has been swapped you might have to look at the crank or measuring a piston
Title: Re: 327
Post by: Blazin on March 27, 2008, 03:41:31 am
The pad in front of the right cylinder head should have numbers on it that will give you a good idea what it is. I have always gone by them and calling a local Chevy dealer.If the block has been decked your SOL though.
Title: Re: 327
Post by: VileZambonie on March 27, 2008, 05:29:28 am
Then Id ing the block won't really help you... You can see if the # is present on the front of the block like Blazin suggested but other than that You'd probably be guessing
Title: Re: 327
Post by: 1976Scottsdale on March 27, 2008, 09:05:13 am
Yeah, 1968 would be a learge journal block, to be a small journal you would need a 1967 or earlier engine.
