		General Site Info => General Discussion => Topic started by: dumbucket1 on March 29, 2008, 09:55:05 am
				Looked at a 87 gmc full size van, it appears the grille would work on a truck, is this correct? What else interchanges with the trucks? Maybe steering column, windshield, rear ends, front suspensions?
				Rear ends are different spring perch width, and overall width. I have never seen nor had it confirmed, but I have heard the windshields are the same. I know a guy that said he used van front suspension parts control arms in his C10.
 hmmmmm Narrower or wider???
				I don't remember but I think it is wider.
				OK never mind :(
				grilles interchange just fine
				The grille will swap up to a certain year, but Vans are Unibody, so the axle perches are different.
				The grill will work. I should know, that's what mine's off of.  ::)
				grilles look the same but won't swap over. when i ordered the new one for my truck a couple years back, gm sent me a van one instead. mounting tabs are different.
				1) the gauge panel interchanges with a chevette/T-1000.
 2) So, this, apparently, means that the parts that interchange with the 73-87-91's actually range from 71 to about 96ish because i don't think the new-style gm vans came out until 97 or so?
				I don't think your gonna get a 71 - 75ish grille in a C K truck!
				i can try;  Wire-ties will do wonders.
				Van grilles were the same/simular from about 81-87...  As far as I know nothing from the 70's will work
